Because your order is made to your specifications it is extremely important to check you have the right size before you make your purchase. You have 48 hours from the time you place your order to change it, we will also confirm your selection with you, before we accept, and confirm the order.
We’ve got you covered! We are all different sizes, and the way size is recorded is different the world over so please check your actual measurements in inches or centimeters before selecting the size you garment.
Measurements
1. Bust - Measure under your arms at the fullest part around the bust, keeping measuring tape horizontal.
2. Waist - Measure around your natural waistline, the narrowest part of your body (torso).
3. Hips - With your feet together measure around the fullest part of your lower body (bum).
4. In-seam - The inside leg seam of a pair of trousers (pants) measured from top to bottom.
Women – USA, UK, EU
| ZC Size | USA | UK | EU | Bust Inches (CM) | Waist Inches (CM) | Hips Inches (CM) |
| XS | 4 | 8 | 30 | 29.5” (75cm) | 22” (56cm) | 31.5” (80cm) |
| 6 | 10 | 32 | 30.5” (77.5cm) | 23” (58.5cm) | 32.5” (82.5cm) | |
| S | 8 | 12 | 34 | 31.5” (80cm) | 24” (61cm) | 33.5” (85cm) |
| 10 | 14 | 36 | 32.5” (82.5cm) | 25” (63.5cm) | 34.5” (87.5cm) | |
| M | 12 | 16 | 38 | 34” (86.5cm) | 26.5” (67cm) | 36” (91.5cm) |
| 14 | 18 | 40 | 36” (91.5cm) | 28” (71cm) | 38” (96.5cm) | |
| L | 16 | 20 | 42 | 38” (96.5cm) | 30” (76cm) | 40” (101.5cm) |
| 18 | 22 | 44 | 40” (101.5cm) | 32” (81.5cm) | 42” (106.5cm) | |
| XL | 20 | 24 | 46 | 42” (106.5cm) | 35” (89cm) | 44” (112cm) |
| 22 | 26 | 48 | 44” (112cm) | 37” (94cm) | 46” (117cm) | |
| 2XL | 24 | 28 | 50 | 46” (117cm) | 39” (99cm) | 48” (122cm) |
| 26 | 30 | 52 | 48” (122cm) | 41.5” (105.5cm) | 50” (127cm) | |
| 3XL | 28 | 32 | 54 | 50” (127cm) | 44” (112cm) | 52” (132cm) |
| 30 | 34 | 56 | 52” (132cm) | 46.5” (118cm) | 54” (137cm) | |
| 4XL | 32 | 36 | 58 | 54” (137cm) | 49” (124.5cm) | 56” (142cm) |
Men – All countries
| ZC Size | Chest Inches (CM) | Neck Inches (CM) | Waist Inches (CM) | Hip Inches (CM) |
| XS | 30-32” (76-81cm) | 12.5” (32cm) | 24-26” (61-66cm) | 29-31” (74-79cm) |
| S | 32-34 (81-86cm) | 13.5” (34.5cm) | 26-28” (66-71cm) | 32-34” (81.5-86.5cm) |
| M | 34-36” (86-91cm) | 14.5” (37cm) | 28-30” (71-76cm) | 35-37” (89-94cm) |
| L | 38-40” (96-101cm) | 15.5” (39.5cm) | 32-34” (81.5-86.5cm) | 39-41” (99-104cm) |
| XL | 42-44” (106-111cm) | 16.5” (42cm) | 36-39” (91.5-99cm) | 43-45” (109-114cm) |
| 2XL | 46-48” (116-122cm) | 17.5” (44.5cm) | 42-44” (106.5-112cm) | 47-49” (119.5-124.5cm) |
| 3XL | 50-52” (127-132cm) | 18.5” (47cm) | 46-48” (117-122cm) | 51-53” (129.5-134.5cm) |
| 4XL | 54-56” (137-142cm) | 19.5” (49.5cm) | 50-52” (127-132cm) | 54-56” (137-142cm) |
